Supports with PETG causing ugly surface on overhangs
Using PrusaSlic3r, with PETG, the support material is REALLY bonding to the print surface.
As a result, in overhangs it is very difficult to remove the supports. In some cases, it damages the object print surface (effectively leaving it VERY rough or misshapen)
Any tuning to the Prusa Slic3r to address this?
I am experimenting with CURA to see if it has the same issues.
Opublikowany : 30/05/2020 2:57 pm
