Support Problem
Bob Hengen
(@bob-hengen)
Support Problem
Hello,
I need help for the support material settings, i try to print with support but the first layer after the support looks like this.
What can i change to get a propper result ??
Napsal : 25/09/2017 5:03 pm
3D Printing Pro
(@3d-printing-pro)
Re: Support Problem
It seems like there is no adhesion with the support,
from the fisrt layer I would say _underextrusion_ (or wrong first layer height),
maybe also excessive cooling fan on the first layer over the support?
Napsal : 27/09/2017 1:59 pm
Bob Hengen
(@bob-hengen)
Re: Support Problem
How can i change this ?
You got some advanced settings ?
Napsal : 05/10/2017 4:30 pm
AJS
 AJS
(@ajs)
Re: Support Problem
I would suggest:
Contact Z Distance 0.2 (detachable)
With Sheath Around YES
Don't Support Bridges NO <- I think Slic3r thinks this is a bridge and does not need supports.
XY separation (90%)
Reasoning:
You want to remove the supports.
You want the supports to stick
You want to make sure it puts supports in (CHECK THE PREVIEW)
You want enough separation from the part that you can get the supports out.
Napsal : 06/10/2017 3:27 am
