strange printing issue x-axis
Knickohr
(@knickohr)
Miembro Moderator
Objects will be wider if the z-axis rises 😮
on the right side the printing is not orthogonal, is oblique to the bed !
How can I fix this ?
Thomas
Respondido : 12/02/2017 8:47 pm
Knickohr
(@knickohr)
Miembro Moderator
Re: strange printing issue x-axis
Issue found ! 😯
It looks like the belt has melted during the print. I do an V2calibration and the filament isn' located on the grid of the bed. After some tries of doing an xyz-calibration, all failed, I do a closer look at the x-axis again and I found an stretched Beld around the stepper of the x-axis. It looks like the pulley is getting hot from the stepper. But i cant beleave this.
Has anyone some similar problem ? I found this topic, it looks similar to mine : http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/stretched-x-axis-belt-t3328.html
Workaround :
I mount the belt vice versa. It works now fine, but I think this problem will appear again. Curios !
Will make an photo later the day. -> here it is :
Thomas
Respondido : 13/02/2017 10:15 am
