[SOLVED] Extruder temperature decrease after the first layer
Stránka 1 / 2
massimo.t
(@massimo-t)
Hi everybody,
I'm new on the forum. I got this problem with my new Prusa i3 1.75 with newest firmware: i set the temperature for the first layer at 220 and for the other at 215 using slic3r. The printer start to work normally but after the first layer the temperature decrease at 190 / 195 . I'm not able to understand why this. If I try to increase the temperature manually from the lcd it doesn't go up.
Anyone can help me?
Thanks in advance.
Massimo.
Napsal : 30/09/2015 4:49 pm
Josef Průša
(@josef-prusa)
Member Admin
Re: Extruder temperature decrease after the first layer
Hi, what Slic3r you use? Does it work with the default settings from the driver package?
Founder and owner / Majitel a zakladatel
Napsal : 30/09/2015 5:44 pm
massimo.t
(@massimo-t)
Thanks for your answer.
I'm using slic3r 1.2.9 with the official settings downloaded from the site.
Napsal : 30/09/2015 6:38 pm
massimo.t
(@massimo-t)
In the pictures attache you can see that I try to increase the temperature from the lcd from 215 to 220 but it still at 190
Napsal : 30/09/2015 6:47 pm
massimo.t
(@massimo-t)
I try again to insert the configuration bundle in slic3r , printing a 15*15*1 mm square with normal pla setting. After the first layer at 210 the temperature decrease at 206 the second layer and at 202 the other.
Napsal : 30/09/2015 7:27 pm
massimo.t
(@massimo-t)
Nobody can help me?
Napsal : 01/10/2015 4:03 pm
Josef Průša
(@josef-prusa)
Member Admin
Preheat the ozzle for the temps you want, then try turning on the fan from LCD menu at 210 and let me know if the temp will go down.
Napsal : 01/10/2015 4:06 pm
massimo.t
(@massimo-t)
Ok, as soon I will back home I will try.
THANKS,
Massimo.
Napsal : 01/10/2015 4:08 pm
massimo.t
(@massimo-t)
Hi Josef,
preheated at pla temperature and turn on the fan from lcd: temperature is fixed to 210. Is a good things or not?
Napsal : 01/10/2015 5:55 pm
massimo.t
(@massimo-t)
I've tried to reduce the fan speed during the print and the temperature is more stable but I have to change it every layer, no way to solve this?
Napsal : 01/10/2015 6:26 pm
Josef Průša
(@josef-prusa)
Member Admin
Can you post a screenshot of the slicer filament settings you use?
Also check if the hotend power connector is properly secured in the motherboard and the cables are properly screwed inside the connector housing.
Napsal : 02/10/2015 10:34 am
massimo.t
(@massimo-t)
Good morning Josef,
attached the printer settings as you ask me.
They are the default from last 1.6 package.
Bye,
Massimo.
Napsal : 02/10/2015 12:05 pm
massimo.t
(@massimo-t)
Problem solved by myself.
Thanks.
Napsal : 03/10/2015 8:02 am
Josef Průša
(@josef-prusa)
Member Admin
Can I ask for the cause of the problem? In case someone else had the same issue?
Napsal : 03/10/2015 5:13 pm
massimo.t
(@massimo-t)
I don't know the cause of the problem, I've asked you for it. Till the cause comes out I've solved removing from slicer filament settings the flag on "keep fan always on" and reducing the min & man fan speed at 50% & 75%. This way the temperature goes from 220 to 210 so is perfect for me.
I hope someone find the origin of the problem.
Massimo.
Napsal : 04/10/2015 8:27 am
Josef Průša
(@josef-prusa)
Member Admin
Can you check if the blower fan duct isnt damaged? If its broken it could direct airflow directly at the heater block.
Napsal : 06/10/2015 11:47 am
massimo.t
(@massimo-t)
Thanks Josef for your reply. I've checked the blower fan duct and it's ok. I understand what you mean but ... isn't it the cause of the problem.
Napsal : 06/10/2015 6:47 pm
Cipis
(@cipis)
I have noticed similar problem today, but only on certain circumstances. I am doing some tests now.
Napsal : 08/10/2015 6:12 pm
massimo.t
(@massimo-t)
Thanks a lot Josef, I look forward to receive your notice.
Bye,
Massimo.
Napsal : 08/10/2015 6:30 pm
Cipis
(@cipis)
Not Josef here 😀
Napsal : 08/10/2015 7:01 pm
Stránka 1 / 2
