[Fermé] slight warping (from the bed)
OZz
 OZz
(@ozz)
So I have read a few articles about this. Any solutions specific to our printers? I have the MK3S and did a few prints successfully but the last one had warped about 2mm from side to side. Any suggestions?
Publié : 02/09/2019 12:56 pm
timo.m
(@timo-m)
RE: slight warping (from the bed)
You'll have to give us more information:
  • Filament used?
  • Print settings? (temps, brim, etc.)
  • Bed cleaning (or other preparation) procedure?
  • Part geometry? (preferably with pictures of the warped part?
  • Environmental conditions? (Room temp, air drafts etc.)
Your question as it is can just be answered by stating the obvious: Parts can warp, certain measures can prevent warping. But I guess that is not of much help...
Publié : 02/09/2019 1:32 pm
OZz
 OZz
(@ozz)
PLA from prusa
215/60 on bed
i use 91% iso to clean
warped part wase the base of the millennium falcon (the 2 halfs that get glued together, so rather large section of flat PLA
75-76 in the house with the AC on (I am in FL)
Thats the best I can do for now, I do NOT have an enclosure onthe printer yet..
Publié : 02/09/2019 5:50 pm
timo.m
(@timo-m)
Try different cleaning of the bed. Many people here would recommend water with dishwasher. Or try using an adhesive like gluestick or hairspray (i use 3DLac).
Try using a brim
Publié : 03/09/2019 12:00 pm
Your underlying issue is bed adhesion. This is a common problem that can be caused or aggravated by two factors that need to work together well for successful prints. Here's mama's tried and true copypasta recipe to get you going...
You are having bed adhesion issues. Filament should lay down cleanly on the PEI print surface and hold throughout the print. There are 2 main causes of bed adhesion issues. Even if you're dubious that these are the cause of your problems, they're 2 fundamental troubleshooting steps that you need to complete to rule out the basics:
  • A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. If it's a smooth PEI sheet, take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails , and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite pad or equivalent on smooth PEI to give it a very light buff, but only infrequently. If you've got a textured powder-coated PEI print surface, the official instructions are to use 91%+ isopropyl alcohol on it only. Rumors persist that some tribes deep in the jungle have had good luck getting started with these sheets by giving them a wipe with 100% acetone and a dunk with Dawn. Either way, there's no real warranty on these sheets. YMMV.
  • If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine. It's much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them.  Then start lowering (more negative) the level until there are no gaps between layers.
And above all else, avoid touching the PEI print surface.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help. If you want more detail, I've consolidated my notes on Prusa PEI adhesion, bed cleaning, and Live-Z calibration
Publié : 03/09/2019 12:56 pm
