Slic3rPE vs PrusaControl
ludodg
(@ludodg)
Hello all,
Am using PrusaControl to slice the prints for my Anet A8.
I get fabulous results with the standard settings of Prusacontrol for the MK2-printer, generic PLA ... but do have some problems when printing something that end in a sharp thin point.
So I would like to switch to Slic3r PE because PrusaCOntrol does not allow you to alter settings.
Another important reason why I use Prusacontrol and would like to use Slic3r PE is because my MK3 has been ordered and should arrive within a couple of weeks (although I just noticed the delevry has been delayed by 4 days ;( )
.. and I would like to get familiar with Prusa-settings.
Now, my question: Are the standard settings used in Prusacontrol for the MK2 the same as in Slic3rPE ?
So in other wors: could I use Slic3rPE MK2-settings and get the same results as Prusacontrol? ... but also being able to change settings and test?
Thx in advance.
Opublikowany : 25/02/2018 1:58 am
