Slic3r Prusa Edition - OpenGL errors
Alan
 Alan
(@alan)
I know there's another thread with an OpenGL error, but i'm getting a different one which kills the variable layer height function. I've tried several versions of my graphics drivers, but they haven't made any difference at all to the error. I've attached a screen shot of the error and my Splic3r log. I'm running Windows 10 on a Panasonic Toughbook CF-52 laptop, by the way...
Version: 1.33.8-prusa3d-win64
Build: Slic3r-1.33.8-prusa3d-win64-full-201702210907
Operating System: MSWin32
System Architecture: MSWin32-x64-multi-thread
Windows Version:
Microsoft Windows [Version 10.0.14393]
Summary of my perl5 (revision 5 version 24 subversion 0) configuration:
Platform:
osname=MSWin32, osvers=6.3, archname=MSWin32-x64-multi-thread
uname='Win32 strawberry-perl 5.24.0.1 #1 Tue May 10 21:30:49 2016 x64'
config_args='undef'
hint=recommended, useposix=true, d_sigaction=undef http://shop.prusa3d.com/forum/download/file.php?mode=view&id=6323
useithreads=define, usemultiplicity=define
use64bitint=define, use64bitall=undef, uselongdouble=undef
usemymalloc=n, bincompat5005=undef
Compiler:
cc='gcc', ccflags =' -s -O2 -DWIN32 -DWIN64 -DCONSERVATIVE -DPERL_TEXTMODE_SCRIPTS -DPERL_IMPLICIT_CONTEXT -DPERL_IMPLICIT_SYS -fwrapv -fno-strict-aliasing -mms-bitfields',
optimize='-s -O2',
cppflags='-DWIN32'
ccversion='', gccversion='4.9.2', gccosandvers=''
intsize=4, longsize=4, ptrsize=8, doublesize=8, byteorder=12345678, doublekind=3
d_longlong=define, longlongsize=8, d_longdbl=define, longdblsize=16, longdblkind=3
ivtype='long long', ivsize=8, nvtype='double', nvsize=8, Off_t='long long', lseeksize=8
alignbytes=8, prototype=define
Linker and Libraries:
ld='g++', ldflags ='-s -L"C:\Strawberry64\perl\lib\CORE" -L"C:\Strawberry64\c\lib"'
libpth=C:\Strawberry64\c\lib C:\Strawberry64\c\x86_64-w64-mingw32\lib C:\Strawberry64\c\lib\gcc\x86_64-w64-mingw32\4.9.2
libs=-lmoldname -lkernel32 -luser32 -lgdi32 -lwinspool -lcomdlg32 -ladvapi32 -lshell32 -lole32 -loleaut32 -lnetapi32 -luuid -lws2_32 -lmpr -lwinmm -lversion -lodbc32 -lodbccp32 -lcomctl32
perllibs=-lmoldname -lkernel32 -luser32 -lgdi32 -lwinspool -lcomdlg32 -ladvapi32 -lshell32 -lole32 -loleaut32 -lnetapi32 -luuid -lws2_32 -lmpr -lwinmm -lversion -lodbc32 -lodbccp32 -lcomctl32
libc=, so=dll, useshrplib=true, libperl=libperl524.a
gnulibc_version=''
Dynamic Linking:
dlsrc=dl_win32.xs, dlext=xs.dll, d_dlsymun=undef, ccdlflags=' '
cccdlflags=' ', lddlflags='-mdll -s -L"C:\Strawberry64\perl\lib\CORE" -L"C:\Strawberry64\c\lib"'
@INC:
C:/PROGRA~1/Prusa3D/Slic3rPE/lib
C:/Program Files/Prusa3D/Slic3rPE/lib
OpenGL installation
Using POGL v0.6704
GL version: 1.1.0
vendor: Microsoft Corporation
renderer: GDI Generic
GLSL version:
Required extensions (* implemented):
GL_ARB_fragment_shader
GL_ARB_shader_objects
GL_ARB_shading_language_100
GL_ARB_vertex_shader
Installed extensions (* implemented in the module):
* GL_EXT_bgra
GL_EXT_paletted_texture
GL_WIN_swap_hint
Any help will be much appreciated... 😉
Opublikowany : 22/04/2017 8:50 am
eVenom
(@evenom)
Re: Slic3r Prusa Edition - OpenGL errors
Try 1.34.1 that update solved all my OpenGL issues
https://github.com/prusa3d/Slic3r/releases
Opublikowany : 22/04/2017 1:18 pm
Alan
 Alan
(@alan)
OK, tried that, now getting a new OpenGL error. Error and new log attached...
Version: 1.34.1-prusa3d-win64
Build: Slic3r-1.34.1-prusa3d-win64-full-201704060808
Windows Version:
Platform:
osname=MSWin32, osvers=10.0, archname=MSWin32-x64-multi-thread
uname=''
config_args='undef'
Compiler:
cc='cl', ccflags ='-nologo -GF -W3 -O1 -MD -Zi -DNDEBUG -GL -fp:precise -DWIN32 -D_CONSOLE -DNO_STRICT -DWIN64 -DCONSERVATIVE -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -DPERL_TEXTMODE_SCRIPTS -DPERL_IMPLICIT_CONTEXT -DPERL_IMPLICIT_SYS -DWIN32_NO_REGISTRY',
optimize='-O1 -MD -Zi -DNDEBUG -GL -fp:precise',
cppflags='-DWIN32'
ccversion='18.00.40629', gccversion='', gccosandvers=''
d_longlong=undef, longlongsize=8, d_longdbl=define, longdblsize=8, longdblkind=0
ivtype='__int64', ivsize=8, nvtype='double', nvsize=8, Off_t='__int64', lseeksize=8
ld='link', ldflags ='-nologo -nodefaultlib -debug -opt:ref,icf -ltcg -libpath:"c:\wperl64\lib\CORE" -machine:AMD64 -subsystem:console,"5.02"'
libpth=\lib
libs=oldnames.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib netapi32.lib uuid.lib ws2_32.lib mpr.lib winmm.lib version.lib odbc32.lib odbccp32.lib comctl32.lib msvcrt.lib
perllibs=oldnames.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib netapi32.lib uuid.lib ws2_32.lib mpr.lib winmm.lib version.lib odbc32.lib odbccp32.lib comctl32.lib msvcrt.lib
libc=msvcrt.lib, so=dll, useshrplib=true, libperl=perl524.lib
gnulibc_version=''
Dynamic Linking:
dlsrc=dl_win32.xs, dlext=dll, d_dlsymun=undef, ccdlflags=' '
cccdlflags=' ', lddlflags='-dll -nologo -nodefaultlib -debug -opt:ref,icf -ltcg -libpath:"c:\wperl64\lib\CORE" -machine:AMD64 -subsystem:console,"5.02"'
@INC:
C:/Users/Alan/Desktop/Slic3r-1.34.1-prusa3d-win64-full-201704060808/lib
OpenGL installation
Using POGL v0.6704
GL version: 1.1.0
GLSL version:
* GL_EXT_bgra
GL_WIN_swap_hint
Opublikowany : 22/04/2017 1:40 pm
eVenom
(@evenom)
So it's pretty much the same error... Hopefully, someone else can help you. You should try to post in the other thread to see if it gets more attention from the admins
http://shop.prusa3d.com/forum/print-tips-slic3r-settings-kisslicer-model-repair--f12/error-with-the-new-slic3r-version-t3656.html
Opublikowany : 23/04/2017 2:57 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
What graphics card are you using? You need at least an OpenGL 2.0 capable graphics card and driver to run the smooth variable layer height editor.
Opublikowany : 27/04/2017 1:07 pm
3Delight
(@3delight)
Moderator Moderator
Alan, from the log file yopu have posted you are using OpenGL v1.1.o and as vojtěch says you need to have a GPU that supports at least OpenGL v2.0.
I'm a bit confused about the log entries:
Does that mean you are running Windows 10 32-bit version? If so then you need to download the 32bit version of slic3r not the 64bit one that you have.
Opublikowany : 27/04/2017 2:19 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
It only means, that the OpenGL driver was not able to create a required OpenGL 2.0 context. The driver may support OpenGL 2.0 for some other set of context parameters. This is a technical issue and a quite confusing one even for me.
Opublikowany : 27/04/2017 2:38 pm
Alan
 Alan
(@alan)
Sorry guys, been extremely busy at work and had to put all my 3D printing to one side.
In answer to the questions, I'm using Windows 10 Pro 64bit. The graphics card is whatever is built into my Toughbook CF52, it's some form of Intel integrated graphics, quite old. I'll have to look into that when I'm at home, as I'm at work now.
Opublikowany : 12/05/2017 2:14 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
https://www.cnet.com/products/panasonic-toughbook-cf-52/specs/
You card may or may not support OpenGL 2.0, but likely it is not wort to waste energy on a 10 years old laptop.
https://software.intel.com/en-us/forums/developing-games-and-graphics-on-intel/topic/300869
Opublikowany : 12/05/2017 2:35 pm
Alan
 Alan
(@alan)
Well, it's now fixed in a round-a-bout sorta way. I switched back to Linux. Long story short, i was only using Windows as i needed Office to write assignments and prepare presentations for a training course i'm doing. Before anyone says it, yes, i've heard of Libre Office, but it's just not quite compatible enough with Office and kept messing things up in my assignments.
Anyway, I setup a dual-boot with Linux Mint and Win10, then installed Slic3r PE from Gabriele's excellent Ubuntu PPA (thanks!). I found a few dependencies were missing in Linux Mint 18.1, so i'll leave those here for posterity...
Running the following in a terminal will get you up and running.
sudo apt-get install wx-common
sudo apt-get install libopengl-perl
sudo apt-get install libwx-glcanvas-perl
TL;DR - Windows sucks, Linux rules, never give up on hardware just because it's old. 😀
Opublikowany : 20/06/2017 8:28 pm
