Slic3r print settings
Zitman
(@zitman)
Hi everyone,
Realise this might be a dumb question but how do I add to the Slic3r print settings (top right)
Ta
Ian
Blog: http://ianmarshall.me
Publié : 09/10/2017 6:26 pm
Marc
 Marc
(@marc-8)
Re: Slic3r print settings
In the tab menu 'Printer Settings' -> USB / serial connection -> Serial port specifications select port and speed (115200)
Publié : 11/10/2017 8:43 pm
AJS
 AJS
(@ajs)
Hi everyone,
Ta
Ian
Change the settings, then in the upper left hand corner is a little save button (disk). It will ask you what to name your new setting. If it is a new name, you will have new items in those settings.
Publié : 12/10/2017 3:28 am
Zitman
(@zitman)
DOH! Knew it would be simple! I had tracked down the files it uses, copied one and then hand edited it and that worked too. Your way is far easier 😀
Thanks
Publié : 12/10/2017 2:10 pm
