Slic3r cannot slice my file correctly
Im trying to print this file but the problem is when im slicing it and the result that Slic3r give me its not what I want.
I went already to settings and click the Thin walls detention but is not giving me a good ending.
I hope someone can help me. Thank you!
Publié : 15/05/2019 5:21 pm
RE: Slic3r cannot slice my file correctly
The model has higher resolution vertices than what a 0.4mm nozzle can print.
Turn off Thin Wall, and change XY Compensation from 0 to 0.2 mm, see what that gives you.
Publié : 15/05/2019 10:04 pm
