Slic3r 1.34.0 prusa edition
Simon
(@simon-6)
I figured I'd share this as it can be pretty significant in the print results.
the recently released Slic3r 1.34.0 prusa edition build fixes the following:
-Improved the speed of AMF import drastically. Fixed a scaling issue when loading an AMF file #7.
-Rotation and scaling did not support decimal values, based on work of @alexrj #41, #104.
-Improved "Seam position aligned" behavior #44.
-Fixed A large fractal pyramid takes ages to slice #117
-Fixed "Zero extrusion print moves and overlapping regions in first layer" #175 #184
-Reworked the variable layer height visualization to use OpenGL 2.0 shaders, fixing many issues #179.
-Fixed Window selections wrong #191, thanks to @uclaros.
-Fixed Slic3r ignoring "slow down if layer print time is below" setting alexrj#3515 thanks to @alexrj
-Fixed "When the Voronoi diagram contained very large coordinates" alexrj#3776, thanks to @alexrj.
-Support generator sometimes Base layers are trimmed by the briding bottom surfaces.
the important one for me is the slow down if layer print time is below that was ignored
ref for other changes and information (which include download links): https://github.com/prusa3d/slic3r/releases
for the moderators, if this should be posted in the software forum instead, feel free to move it.
Publié : 31/03/2017 4:52 pm
