Simple parts: Cura with no zhop better than PE Slic3R?
david.b14
(@david-b14)
Hello,
For simple parts like screw brackets it seems like slicing with Cura would have advantages vs. slicing with PE Slic3R with ZHops because it would reduce movements on the z axis, especially if printing multiple parts. Thoughts?
Thanks,
David
Publié : 04/01/2017 5:56 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Simple parts: Cura with no zhop better than PE Slic3R?
You can always use the "ColourPrint" profile to slice without Z-Lift.
Peter
Publié : 04/01/2017 7:47 pm
david.b14
(@david-b14)
Cool, I will give that a try. Thanks for the info.
Publié : 04/01/2017 8:13 pm
