Shifted X layer
frank.a
(@frank-a)
Shifted X layer
Hello all,
yesterday I tried to print a christmas star twice using my Original Prusa i3 mk2 (using
PETG filament). First time it works perfectly. The second time it started good the first layers but afterwards a layer has been shifted in direction of the X axis.
Could the reason be that the X device got stuck with the filament lump visible in the picture ? If yes how could such lumps be prevented? Could my Slic3r settings be improved ?
Regards Frank
Postato : 25/12/2016 10:03 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Shifted X layer
Reduce extruded amount - set "Flow Tweak" (or similar) to 95%; use Z-Lift and High Power mode.
Peter
Postato : 25/12/2016 10:31 am
david.b14
(@david-b14)
Re: Shifted X layer
I have been trying to master PETG filament printing. The biggest factor for me was slowing down the print. This is critical for layers 1 to 5, then incrementally bump up the speed. If you increase the speed and start seeing blobs, back down the speed.
Postato : 25/12/2016 12:06 pm
david.b14
(@david-b14)
Re: Shifted X layer
@Peter: How does High Power mode change things? Does is smooth the blobs produced by PETG since the steppers have more power?
Postato : 25/12/2016 12:10 pm
frank.a
(@frank-a)
Re: Shifted X layer
Hi - I changed to high power mode and restartet the print. Unfortunately I got another filament lump and had to cancel the print again.
@David: OK, I will try to fiddle around adjusting speed settings...
Postato : 25/12/2016 12:35 pm
david.b14
(@david-b14)
Re: Shifted X layer
I adjust the speed using the LCD knob. I also take off the enclosure of my setup so when the PetG lays down, it sticks to the previous layer. Who makes the PetG filament you are using? I am using eSun and I got better results when dropping the nozzle temp which helps prevent the blobs.
I found increasing the layer height help with the blobs. I print at .20mm but anything smaller the blobs come back.
Postato : 25/12/2016 1:29 pm
frank.a
(@frank-a)
Re: Shifted X layer
I bought REAL PETG filament from reprapworld.com.
I also tried out to reduce my nozzle temperatur from 245° (first layer) / 245° (further layers) to 240° / 230 °. Using that temperatures I was able to finish my print. We will see if the problem reoccurs for further prints...
Postato : 25/12/2016 7:15 pm
david.b14
(@david-b14)
Re: Shifted X layer
Cool, what layer height did you print with?
Postato : 25/12/2016 9:47 pm
frank.a
(@frank-a)
Re: Shifted X layer
I am currently printing with 0.2mm layer height. Probably will give 0.4mm a try to save time for some prints in the future 🙂
Postato : 27/12/2016 4:59 pm
david.b14
(@david-b14)
Re: Shifted X layer
I've come across another trick for PetG. If the 1st layer is not sticking in one area I stop the print, put down some blue tape in the problem area, and restart the print. I take a nail file and rough up the tape and this lets the PETG grab it.
Postato : 27/12/2016 5:36 pm
frank.a
(@frank-a)
Re: Shifted X layer
I am using a glue stick on the bed and had no problems so far. It also depends on the Z adjustment, if the first layer sticks well, but you cannot get too close to the bed to prevent the nozzle to smear over the first layer...
Postato : 27/12/2016 5:40 pm
david.b14
(@david-b14)
Re: Shifted X layer
Thanks for the glue tip with PETG. I just tried it and it is far superior than what I had been doing.
Postato : 28/12/2016 1:31 am
