Sequential Pritning
james.o7
(@james-o7)
Sequential Pritning
I am trying to print multiple parts and I keep getting a message that "the parts are too high and will collide with the extruder."
I understand its concern, but the parts are far apart enough that it shouldn't collide with the X-axis rod. Any way around this?
Postato : 29/04/2017 4:42 pm
eVenom
(@evenom)
Re: Sequential Pritning
what are you trying to print and what slicer are you using?
Postato : 02/05/2017 1:39 am
james.o7
(@james-o7)
SLIC3R
Postato : 04/05/2017 12:13 am
eVenom
(@evenom)
Just tried it and it worked for me. It may be the file you are printing or something
Postato : 04/05/2017 2:51 am
james.o7
(@james-o7)
I had to increase the X-axis height to 100mm. I believe the true value should be 35mm.
I had to lie so it think it clears the other object.
On that note, which item does it print first, closest to the origin?
Postato : 06/05/2017 1:25 am
eVenom
(@evenom)
the first one you import in my testing but you can use a gcode previewer to see exactly what is going to happen
Postato : 06/05/2017 3:08 pm
Vojtěch Bubník
(@vojtech-bubnik)
Utenti Admin
It sorts the object by their height, lowest first.
Postato : 12/05/2017 3:24 pm
