Selectively removing generated support material
mihies
(@mihies)
So I have an object that has one big hole that requires support and a bunch of cylindrical small ones that don't require support.
When I turn on Slic3r support generation it generates support for all of them.
Now, is there a way to either get rid of non-required ones or to manually select where I like support to be generated?
Note: small holes are cylindrical and horizontal, like 3mm in diameter.
Napsal : 14/04/2017 9:11 am
vitor.j
(@vitor-j)
Re: Selectively removing generated support material
You can use Meshmixer (free) to add manual supports.
Can you share the STL?
Napsal : 18/04/2017 5:27 pm
david.b14
(@david-b14)
The meshmixer support feature is pretty amazing base off of this vid:
http://www.mold3d.com/blog/2014/5/13/adding-custom-3dprinting-supports-in-meshmixer
I will start using it as my new workflow.
Napsal : 18/04/2017 6:57 pm
