Selective wall thickening
Is there a way to create extra wall thickness in specific parts of a model? I am printing 2 parts who will be fastened together with a pocket hole+screw, i.e. the "results" of a Kreg jig. I created a thin tube in the wall where the screw will attach, so there are the standard 3 wall layers there. Is there a way to create more solid mass in that area so that the screw threads have more to bite on?
Thanks!
Opublikowany : 22/06/2017 9:10 pm
Re: Selective wall thickening
You could use a modifier mesh to set the infill to 100% where you need more strength.
See this thread:
http://shop.prusa3d.com/forum/software-f13/is-it-possible-to-set-different-infil-density-for--t4744.html
-Kevin
Opublikowany : 23/06/2017 1:11 am
