Replacement parts
richard.l
(@richard-l)
Member Moderator
Replacement parts
I would like to print a set of replacement parts but cannot find recommended settings for them. Shells, infill, layer size, etc.
Posted : 22/01/2016 10:57 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Replacement parts
Hi Richard
I just used standard settings - 0.2mm layer with 16% infill
Peter
Posted : 22/01/2016 11:18 pm
ThisIsMUD
(@thisismud)
Good question!
Also ABS or PLA? I'm guessing ABS since that is what the replacement parts are made of in the PR shop.
Posted : 23/01/2016 6:07 pm
PJR
 PJR
(@pjr)
ABS for the extruder parts, but I have printed some in PLA.
Peter
Posted : 23/01/2016 6:43 pm
Josef Průša
(@josef-prusa)
Member Admin
Basically everything can be printed in PLA if you don't live in extremely hot country. Just don't leave the printer in a car on direct sunlight.
Founder and owner / Majitel a zakladatel
Posted : 24/01/2016 4:38 pm
zach.c
(@zach-c)
I'm in the country which is having 37-41 C most of the time at noon. Can the PLA survive? Or should I use XT series filaments? I'm about to shop for more filaments. My printer survive in 40 hrs plus printing and it has been giving good results to me. I was so worried the electronics will burn cause the heat from the nozzle head was heating the entire room 🙂
Posted : 13/04/2016 7:43 pm
PJR
 PJR
(@pjr)
Zach
You should be OK. PLA will start to soften around 50 to 55 degrees. Up to you if you want to try other materials, but I would advise getting used to the printer with PLA first as it is the easiest material to print with.
Peter
Posted : 13/04/2016 10:19 pm
zach.c
(@zach-c)
Hehehe I will try to print some parts and test it outdoor to see 🙂 if it survives I don't really have to worry about it.
Posted : 14/04/2016 1:08 am
PJR
 PJR
(@pjr)
Zach
I don't know if you have seen this map of "original" users: https://fusiontables.googleusercontent.com/fusiontables/embedviz?q=select+col0+from+1mmZsdWsLpnRsGl1o_GFIMfxdVrIoBNW00b2x1Kdo&viz=MAP&h=false&lat=39.466227628871614&lng=-44.19143881875003&t=1&z=2&l=col0&y=2&tmplt=2&hml=GEOCODABLE
It does show quite a few people around the equator...
Peter
Posted : 14/04/2016 9:26 am
eric.e7
(@eric-e7)
I have everything printed in PLA with the exception of the extruder cover and body. Is the cover and body ok to print with PLA?
Thanks
Eric
Posted : 19/01/2018 10:47 pm
