Puttin files on SD Card or Ponterface?
gary.d
(@gary-d)
Hi all,
My computer does not seem to want to recognize the SD card that activates my i3. I was thinking to just drop gcode files onto the SD card and run them from there but now that seems to be a problem. Can I place them there through the PCB using Ponterface? I'm unclear about this process so any advice would be very much appreciated.
Thanks in advance?
G
Publié : 10/12/2015 9:03 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Puttin files on SD Card or Ponterface?
Hi Gary
First thing is that if you are thinking about transferring gcode files over a serial connection, then you could well be in for a long wait.
Does your printer recognise the SD card and if so, can you "see" the files contained on it? Press the button, go down to SD Card (with the card inserted) and press the button again. You should get a list of the gcode files on the card.
If the printer can read the card, then you should be able to take the card out of the printer and put it into an SD card reader, open "My Computer" and you should then see the card there. If not, then you either have a problem with the card reader or the card itself.
Please try the above and let us know your results.
Peter
Publié : 10/12/2015 9:11 pm
gary.d
(@gary-d)
Hi Peter, thanks for quick reply! Did all of that. SD in printer works fine and I have completed print from SD card so card is fine in terms of interacting with printer. However, Somehow my computer does not recognize the SD card. I suspect my card reader may be at fault. I will get another today and try that. Or if you have other digestion I'm open to it!
Again, thank you.
G
Publié : 10/12/2015 10:43 pm
PJR
 PJR
(@pjr)
Hi Gary
Is your SD card reader connected directly to the PC or via a hub? If via a hub, then try connecting it directly to the PC, otherwise try swapping over the cable. Then it would possibly be worthwhile getting a replacement card reader. They are very cheap nowadays.
Peter
Publié : 10/12/2015 10:49 pm
gary.d
(@gary-d)
Hey Peter, problem resolved! Turns out my computer didn't like the micro adapter but when I plugged the micro SD directly into the computer it works fine. Thanks for helping to troubleshoot this with me!
G
Publié : 10/12/2015 11:43 pm
PJR
 PJR
(@pjr)
Hi Gary, well done and thanks for letting us know.
Happy printing!
Peter
Publié : 11/12/2015 8:52 am
russ.j2
(@russ-j2)
Also... another thing to mention for those who wishing to print using Ponterface. Make sure you you adjust your computer settings so that your computer does not time-out mid-print. Learned that quickly the hard way, now I only print with SD card.
Publié : 20/12/2015 2:59 am
Brian Greul
(@brian-greul)
If I was going to use USB I would have a dedicated computer. This is very common in CNC machining. The long run time is called a "drip feed" because it drips code to the onboard computer a bit at a time. 🙂
Publié : 29/01/2016 11:16 pm
PJR
 PJR
(@pjr)
Brian
That's why there is OctoPi/OctoPrint which runs on a Raspberry Pi and controls the printer via USB with a webCam and web interface.
Well worth the investment.
Peter
Publié : 29/01/2016 11:23 pm
Brian Greul
(@brian-greul)
I'll look that up and check into it. I'd love to have a network interface on my printer. 🙂
Publié : 07/02/2016 4:47 am
PJR
 PJR
(@pjr)
Brian
It is very good and exceedingly useful (for me at least). It is also possible to use a WiFi dongle, but if you go that route, you will also require a powered USB hub .
I use a 2A phone USB charger to power the Pi and have a MS webcam on one and a full HD Canyon webcam on the other, but you do have to check the list of supported webcams.
Peter
Publié : 07/02/2016 10:10 am
