Problems with slic3r adding wrong layers
Sabotaz
(@sabotaz)
Hello people,
i am trying to print a stand for a model.
This is the stand how it should look like.
and this how it is sliced by slic3r, enclosing all the details.
This doesn't happen if I rotate the Model on the x or y axis, which doesnt really help in printing it.
Does anyone probably had a similar issue or know why this is happening
Thanks for any tips.
Veröffentlicht : 21/10/2016 12:22 pm
Vojtěch Bubník
(@vojtech-bubnik)
Mitglied Admin
Re: Problems with slic3r adding wrong layers
Would you please post the STL here? Thanks
Veröffentlicht : 22/10/2016 11:36 pm
Sabotaz
(@sabotaz)
Since it says: "Invalid file extension: codsworth_base.stl" when i try to upload it, ill just give you the Thingiverselink.
http://www.thingiverse.com/thing:1202520
There it is the codsworth_base.stl
Veröffentlicht : 23/10/2016 2:07 pm
Vojtěch Bubník
(@vojtech-bubnik)
Mitglied Admin
Thanks. I can reproduce the problem. Slic3r complains about the model having errors. The model is very detailed and it contains details, which are far beyond the resolution of the printer. You can try to fix the model using the netfabb.
Veröffentlicht : 23/10/2016 2:21 pm
Sabotaz
(@sabotaz)
Okay i'll give it a shot, thanks so far.
Edit: The preview in Slic3r now looks fine, so ill see tomorow how its gonna print out.
Big Thanks
Veröffentlicht : 23/10/2016 3:00 pm
