Prints do not keep dimensions in Z axis
marcin.c
(@marcin-c)
Hey guys.
I have this odd problem which is my prints keep comming out inaccurate in Z axis. For example something is 164mm tall instead of 159, 91mm instead of 89mm and such. Any idea what's wrong and how can I fix it? It makes printing big, multiple part objects impossible :<.
Napsal : 11/07/2016 11:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Prints do not keep dimensions in Z axis
Marcin
Is this a slicer issue? Check the GCode files to see the final layer height in GCode.
Are you using Mk1 or Mk2?
Peter
Napsal : 12/07/2016 9:38 am
marcin.c
(@marcin-c)
Sorry for the late reply but I've been busy. Okay so I'm using Mk 1 and the problems is most likely not software related since it happens with Cura and Simplify3D.
Napsal : 17/07/2016 1:14 am
PJR
 PJR
(@pjr)
Marcin
Have a look at the GCode (open it with a text editor such as Notepad++) to see what height Z is set to for the last layer.
Either that or upload the GCode and I will have a look for you. You will also need to tell me the height of the printed model for the uploaded GCode.
Peter
Napsal : 17/07/2016 11:37 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
This is weird. We would expect the objects to be shorter instead of taller, if the motors skip steps. Are you sure the objects are longer?
Would you please provide us with your G-code?
Thanks, Vojtech
Napsal : 18/07/2016 5:36 pm
marcin.c
(@marcin-c)
Sorry for taking this long, busy week ;). Anyway, here's everything you've asked
https://mega.nz/#!JoQ1SIhR
Napsal : 24/07/2016 12:49 pm
PJR
 PJR
(@pjr)
The download is requesting a decryption key. Can you zip up the file and upload it to here (drag and drop on a new post).
Thanks
Peter
Napsal : 24/07/2016 1:00 pm
marcin.c
(@marcin-c)
Sure, when I saw it doesn't accept gcode files I decided to use Mega instead ;).
Napsal : 24/07/2016 1:08 pm
PJR
 PJR
(@pjr)
OK, so the last layer (796) is set to print at 159.18.. Layer 1 is set to 0.18, and the remaining layers to 0.2mm.
That is an issue with the Mk1 as the first layer minimum is 0.23mm, but that will be compensated by over extrusion on the second layer.
Question: what firmware are you running on the Mk1?
Peter
Napsal : 24/07/2016 1:21 pm
PJR
 PJR
(@pjr)
OK, there are 2 things I can think of:
1. Factory Reset
2. include the code "M92 E4000" in the start GCode (without the quotation marks).
Peter
Napsal : 24/07/2016 1:29 pm
marcin.c
(@marcin-c)
Thank you. I will test it as soon as I can and let you know if it works. My firmware version is 2.2.1 (Mk 1) btw 🙂
Napsal : 24/07/2016 3:32 pm
