Printing gcode file
Hello,
AFAYK the gcode file contains commands/movements to print an object. If I move that file between printers, I should have the same movements.
Well, until here ok.
Makes it differences if I print the same code via SD card of my Prusa MK2 or if I send it via serial port (USB) using Pronterface?
I know if Pronterface hangs the print stop, but this isn't the question.
I'm using Pronterface to monitor the status of the print from remote.
Thanks all for the hints!
Simon
Opublikowany : 25/11/2016 9:10 am
Re: Printing gcode file
No difference, you should get the same output.
Opublikowany : 25/11/2016 9:15 am
Topic starter
answered:
Thank you!
Opublikowany : 25/11/2016 3:24 pm
