Printing a solid raft of PETG under Nylon
I've been struggling to print Taulman bridge nylon without the corners lifting (this part: https://www.thingiverse.com/thing:2020729 ). Brims, glue stick, EVA glue, and all the normal suggestions have failed. Then I stumbled across a suggestion to print a solid raft of PETG beneath the Nylon and it works great. To minimize editing gcode I'd like to have Slic3r generate a solid raft (not the 50% version that it generates normally) below the part. I don't see any way to do this other than adding some additional thickness to the part and doing a material change (M600) after the first layer. That works fine for parts I design, but not so well for anything I download.
Any suggestions?
Postato : 13/09/2017 5:31 pm
