Printer Freezes-no clue why?
james.o7
(@james-o7)
My printer froze in the middle of the night. No warning messages or anything. Nozzle was still on and hot and created a small puddle of plastic on my print.
Anything would cause the printer to freeze and keep the nozzle hot?
Posted : 29/04/2017 4:37 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: Printer Freezes-no clue why?
what did you print ? a model that came with the printer ? or something that you've sliced with slic3r ?
once i had the same, but it was related to the fact that i sliced my object with slicer (one of the previous releases) and copied the *.gcode to the sdcard while slic3r itself was not ready with slicing.
so the *.gcode was incomplete and ended in the middle of the print.... with the same effect that you've described.
Posted : 29/04/2017 5:49 pm
james.o7
(@james-o7)
interesting....it was my own part and slice.
I'll re-slice and try again but I didn't think I could output Gcode without the slicer finishing.
Posted : 29/04/2017 7:33 pm
JeffJordan
(@jeffjordan)
Member Moderator
...I'll re-slice and try again but I didn't think I could output Gcode without the slicer finishing.
- in fact this was possible with previous slic3r versions... and caused a few problems (like the ones you describes) -
you can simply look inside the failed *.gcode file (it's a text file) with an editor.
is there a proper "end script", similar to this: M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
G1 X0 Y200; home X axis
M84 ; disable motors
or does it end with something like this: ...G1 X138.516 Y111.946 E0.0053
G1 X138.316 Y111.946 F349...
Posted : 29/04/2017 8:26 pm
kevin.r5
(@kevin-r5)
You can load and preview g-code in CraftWare or Simplify3D (even if it was produced by a different slicer).
-Kevin
Posted : 30/04/2017 2:45 am
TiccTech
(@ticctech)
I haven't tried it, but there's also a g-code viewer and analyzer at http://gcode.ws/ which looks interesting.
Posted : 30/04/2017 4:19 am
Mario
(@mario)
gcode.ws is my goto page to preview gcode files, especially considering it works locally in your browser without uploading anything, so you can even use it on a laptop that's not connected to the internet.
Posted : 03/05/2017 3:46 pm
james.o7
(@james-o7)
I unfortunately over-wrote the Gcode, but these are get tips if this happens again. thanks
Posted : 04/05/2017 12:12 am
