Print resolution
Nathalie
(@nathalie)
Print resolution
Hello,
A simple a stupid question :
With Slic3r where qo you define the resolution of the print
as it is on the sprint sample of the frog on the Prusa site ( http://www.prusa3d.com/ )
there are 4 frogs in
ULTRA - DETAIL -NORMAL - DRAFT
Where do you define those parameters?
Thanks in advance and sorry for that stupid questions
Postato : 14/09/2016 11:23 am
David T.
(@david-t)
Re: Print resolution
http://manual.slic3r.org/simple-mode/simple-mode#print-settings
Look for "Layer height".
Postato : 14/09/2016 11:46 am
Nathalie
(@nathalie)
ok :
by defaut Slic3r is at 0.4mm height
so it is a super super draft resolution.
There is no other params?
Postato : 14/09/2016 12:38 pm
David T.
(@david-t)
Extrusion width.
It defines how thick lines extruder "draws". It should not be smaller then nozzle width.
It's in advanced settings.
Layer height should not be more than 75% of nozzle width (0.3mm for 0.4mm nozzle).
Postato : 14/09/2016 1:44 pm
