PE Slic3r, Multi-Material with PVA for supports automatically?
david.b14
(@david-b14)
Hello,
I am interested in printing mostly parts.
Will there be an option w/ PE Slic3r to print the model with one material and the support structure in a material like PVA without creating two STL files?
If not should I budget extra money to purchase Simplify3D along w/ the MM upgrade?
Opublikowany : 05/05/2017 1:01 am
Cipis
(@cipis)
Re: PE Slic3r, Multi-Material with PVA for supports automatically?
Yes, it is possible...and more :-). Grey = soluble filament.
Opublikowany : 05/05/2017 11:08 am
eVenom
(@evenom)
Could you elaborate?
Opublikowany : 07/05/2017 3:00 am
david.b14
(@david-b14)
So the slicer automatically used the grey PVA for the support interface layer, correct?
Opublikowany : 20/05/2017 6:09 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
The support interface can be set to whichever "extruder" contains the PVA/support material.
Peter
Opublikowany : 20/05/2017 11:01 pm
