PE Slic3r failed to slice this object properly
Hello,
The PE Slic3r failed to slice the blade on this object, it did work in Cura:
Napsal : 15/01/2017 1:27 pm
Re: PE Slic3r failed to slice this object properly
Well, the STL is corrupted, but Slic3r manage to fix it. But I think the root cause is the size of the rotor axes, I have to go down to 0.05 mm profile so that it can been sliced.
I'm like Jon Snow, I know nothing.
Napsal : 15/01/2017 8:16 pm
Topic starter
answered:
I double the size and sliced it in Cura, it printed pretty good. If I print another I may try it again in PE slic3r.
Napsal : 15/01/2017 11:39 pm
Topic starter
answered:
If printing at 2x the size, a Q-tip wrapped in aluminum tape works well for the spindle. For the 1x size a paper clip will do the trick.
Napsal : 16/01/2017 10:54 am
