Object with supports?
Asraff Amzani
(@asraff-amzani)
Would like to ask if this is a normal issues to have http://share.pho.to/AiLHE ?
Someone asked me to print a part that I can't get away with supports, and this object I let it standing like a mushroom. The option that I turned on is "detect bridging parameters". Will there be a difference if I were to turn it off?
Here is what I turned on apart from stock mk2 slic3r settings
- extra perimeters if needed
- detect thin walls
- detect bridging parameters
Other settings are 3 top/bottom and perimeters. This particular object are printed in 100% infill, previously with 20% on cubic pattern, also produce the same output
Other printing details:
- Magma fluorescent green ABS
- 230 on first, 240 on rest
- bed at 100
- speed based on stock mk2 slic3r settings
Posted : 31/05/2017 5:56 pm
