Nozzle drags across model at end of print
Seth
 Seth
(@seth)
Hi, this is probably an easy fix in Slic3r, I just can't find it.
At the end of any print (the gcode of which I generate in slic3r), the nozzle seems to actually lower a bit and drags across whatever the final part was, leaving a nasty scar. Any ideas why this is happening?
Seth
Postato : 11/10/2016 12:11 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Nozzle drags across model at end of print
Seth
All a Z lift in the end GCode section before the move away from the model
G1 Z<Z+1> F300 ; lift Z
G1 X0 Y200 F1200 ; move away
You need to replace the Z part with the command relevant to your slicer.
Peter
Postato : 11/10/2016 9:24 am
simon.p
(@simon-p)
Seth
That sure sounds unusual. It definitely shouldn't lower. I assume you checked your end g-code in Slic3r and possibly OctoPi?
Postato : 22/10/2016 12:22 am
David T.
(@david-t)
I use this ending gcode move-away commands:
G91 ;set relative mode
G1 X-255 Y200 Z30 F1200 ;move 30mm up and to the back corner
G90 ;back to absolute mode
It works regardless of current position of extruder.
Postato : 22/10/2016 10:48 am
