nozzle dipping/scratching after print
james.o7
(@james-o7)
When my print is done by nozzle seems to dip a bit and scratch my parts as it moves to X=0. Is there a setting I can do to prevent this?
Veröffentlicht : 23/09/2017 7:30 pm
AJS
 AJS
(@ajs)
Re: nozzle dipping/scratching after print
Depending on your slicer, you can change what code is placed at the end of the print. Adding a small Z up command should fix this.
Veröffentlicht : 23/09/2017 8:53 pm
