New Slicer Update - Question
Maker Matthew
(@maker-matthew)
As you may have seen, there is an updated version of Sicer3 available on the PRUSA drivers page. Te updates include - The Slic3r 1.39.1 final release brings an accurate print time estimator, a recommended object thin wall thickness hint, and a handful of bug fixes.
I have a few questions about the "recommended object thin wall thickness hint". Truth be told, I don't get the hint. The hint varies depending on what setting you are using, but I am unsure what the lines it is referring to. For example in the MK3 0.2mm setting the hint says - Recommended object thin wall thickness for layer height 0.20 and 2 lines:0.86mm, 4 lines:1.67. First, I assumed this hint was in reference to spiral vase, but when using this feature you can not adjust wall thickness can you (would love to be a able to, though)? Second, what lines are they referring to? Does the number of lines refer to perimeters or something else.
Perhaps I have this all wrong. Any clarity the forum can offer would be greatly appreciated.
Matthew
Napsal : 09/03/2018 8:35 pm
Re: New Slicer Update - Question
in Spiral Vase mode, you can marginally increase the wall thickness by adjusting the extrusion width setting
Napsal : 09/03/2018 10:21 pm
like this
[attachment=0]20180309_222148[1].jpg[/attachment]
the box on the left was set to .8mm extrusion width, whilst the one on the right was set to .45
Napsal : 09/03/2018 11:25 pm
Maker Matthew
(@maker-matthew)
HI Joan,
Thanks for the tip! I appreciate the insight. I will try that with the vase I am working with.
BR
Matthew
Napsal : 10/03/2018 2:34 pm
