Need help improving adhesion
Simon Miller
(@simon-miller)
I am new to 3-d printing, I built this kit and had a successful calibration and 3-4 days of really good prints. All of the sudden I am having adhesion issues. Problem 1 is edges that keep warping/peeling up. Problem 2 is the first layer has issues sticking. This usually only happens on sharp or difficult angles. I have set the layer height using the calibration code found on the forums here and also done the atomic/cold pull with no luck. I also clean the pei regularly with rubbing alcohol. What else can I check?
[attachment=0]IMG_0857.JPG[/
attachment] What else can I check?
Respondido : 02/03/2017 12:12 pm
christophe.p
(@christophe-p)
Miembro Moderator
Re: Need help improving adhesion
Hi Simon,
seing all the traces from previous prints, the first thing you have to do is a good cleaning procedure before a new print.
IPA is recommended for that, using 99% if you have. And from time to time, I use some acetone (please use proper ventilation after using it !) which is really efficient.
I'm like Jon Snow, I know nothing.
Respondido : 02/03/2017 3:51 pm
Simon Miller
(@simon-miller)
Ok will try additional cleaning
Respondido : 03/03/2017 2:38 pm
