MK2 supports to prevent artifacts in prints vs. quiet printing
In reading this forum users have made supports for their MK2 to improve print quality and also to reduce noise while printing.
For example....
- The Z-Frame feet prop up the Z-Frame by about 2mm. This is enough to help prevent the machine from oscillating. I've had problems with that causing artifacts in the past.
If possible could you place links to the supports you have designed and how it has changed printing (better print quality vs lower noise).
Would Z-braces ( http://www.thingiverse.com/thing:921948 ) be of any benefit?
Are there support structures anyone is using if they are moving the MK2 on a regular basis?
Opublikowany : 17/11/2016 2:57 pm
