MeshMixer Supports
eVenom
(@evenom)
MeshMixer Supports
I am trying to set supports in MeshMixer but no matter the settings I try they always break mid print. Do you guys know settings that work to use these supports? I have another printer that I always used these type of supports and never had this issue. Granted is not an i3 style but I am sure there has to be a way to make them print without breaking in the MK2
Respondido : 25/03/2017 5:02 am
martin.w3
(@martin-w3)
Re: MeshMixer Supports
Going slower might help or setup thicker supports in Meshmixer. Hope it helps.
Respondido : 28/03/2017 12:58 am
PJR
 PJR
(@pjr)
Antient Member Moderator
When printing with supports, I have always found it better to use Z-Lift.
Peter
Respondido : 28/03/2017 12:17 pm
eVenom
(@evenom)
I'll try even thicker supports and z-hop. Hopefully I find a setting that works and don't make the support too thick
Respondido : 29/03/2017 5:38 am
