Material change during print
andres.t
(@andres-t)
I'm interested in changing the materials/colors during print.
I found something about a M600 code but I don't know where to insert it in the G-code.
I want the printer to stop at Z 2.5mm, move up 50mm and move 50mm to the side, then I want to change the material and have the printer to resume the print.
So far the printer stops right after the start line it makes on the bottom left corner on every print. (when I insert the code in Start-G-code.)
Or, after every layer. ( if i insert the code in "before layer change".)
I'm using Slicer Prusa edition.
Thanks in advance!
Publié : 12/02/2017 10:48 am
Re: Material change during print
Try this thread
http://shop.prusa3d.com/forum/software-f13/color-change-script-broken--t2513.html#p19946
Publié : 12/02/2017 11:24 am
