Lowest ambient temperature for printing?
walter.l
(@walter-l)
Hello!
Winter is coming , it's getting cold and my printer is in its own little room. Heating means money, so I want to heat only as much as needed.
What is the lowest ambient temperature, I have to provide for my printer, without having to worry about warping or similar problems? I just print PLA, nothing fancy...
Napsal : 14/10/2017 8:00 pm
Re: Lowest ambient temperature for printing?
I believe the printer currently gets fussy at 15 centigrade
Joan
Napsal : 14/10/2017 10:16 pm
walter.l
(@walter-l)
Thank you very much for the quick reply!
I will make sure to keep the ambient temperature above 15C.
Napsal : 15/10/2017 12:52 am
mihies
(@mihies)
Note that printer works in lower temperatures just fine (I'm printing on 0-10C). It's just the firmware that prevents printing start because it safeguards against wrong sensor readings.
you can heat it with a hairdryer to reach min temperature...
Napsal : 05/12/2017 9:04 am
