LCD shows no extruder-temperature during print
Hello,
during Bed and Extruder heating the LCD shows all 4 tempetatures (like 210/210 and for Bed 52/52 if the heating is done).
If the Print starts, i see no temperatur for Extruder (0/210 Bed 52/52).
The Printer prints normal and i have no problem with the prints.
I use Cura.
My startcode:
M190 S60.000000
M109 S210.000000
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 X4.0 F2000
G1 Y60.0 E4.0 F1000.0
G1 Y100.0 E8.5 F1000.0
G92 E0 ;zero the extruded length
G1 E-1 F300 ;retract the filament a bit
G92 E0 ;zero the extruded length again
G1 F9000
M117 Printing... ;Put printing message on LCD screen
;Layer count: 301
;LAYER:0
M107
G0 F9000 X78.482 Y76.889 Z0.200
;TYPE:SKIRT
G1 F1200 X79.706 Y75.838 E0.05366
G1 X81.017 Y74.711 E0.11116
Have anyone a Idea why i have no Extrudertemp.?
Peter
Re: LCD shows no extruder-temperature during print
Peter
I use slic3r settings from Joseph Prusa's website. Perfectly defined for the Prusa I3 . As regards Cura steal some of the slic3r settings.
Nigel
Hello Peter,
thank you for your answer.
i use Cura, Slic3r and Kisslicer.
I see this bug when i print with Cura.
I've not tested it with Slic3r or Kisslicer but i will test it at Monday evening.
Then i tell you the result.
Peter
