Large distance to support for angled surface?
Hi. I have a model which I need to print with supports. However the results are mediocre compared to other prints with supports, and upon closer look in Slic3r, I noticed that the support seems to have a larger distance to the model than on plane (rectangular) surfaces.
Is there a way to get a similar close distance to the model? I played with the settings in Slic3r but none seems to make the support/model distance the same for the angled vs. plane surface.
Default Slic3r PE settings for 0.10mm with supports. Version 1.37.2
Any ideas?
Thanks
Opublikowany : 24/11/2017 10:51 pm
