It appears that Slic3r does not emit gcode to slow down the first layer of a print?
OldCoder
(@oldcoder)
Unless I am configuring it incorrectly, it appears that Slic3r does not actually emit gcode to slow down the printing of the first layer?
I'm finding that I have to manually slow down the print speed using the 'Tune' command on the user interface to get the first layer to stick reliably when printing Hatchbox PTEG.
Under 'Print Settings', I configured 'Modifiers, First layer speed' to 50%. Yet, when I export the gcode to the SD card, and then attempt to print the file, it starts out printing at whatever print speed the last job used? I would have expected Slic3r to emit gcode to change the print speed as a result of my setting the 'First layer speed to 50%'?
Thank you,
Chris Shaker
Publié : 18/12/2016 10:53 pm
Ancientwolf
(@ancientwolf)
Re: It appears that Slic3r does not emit gcode to slow down the first layer of a print?
By chance after setting the speed are you reslicing the print? Havent had it not use the settings. Using current version, etc?
Yeah, its that guy... 3D Nexus
Publié : 19/12/2016 12:13 am
OldCoder
(@oldcoder)
Running the latest Prusa Slic3r from driver version 1.7.5: version 1.31.6-prusa3d-win64. I just loaded a part into Slic3r, and output the gcode for you
Publié : 19/12/2016 12:55 am
OldCoder
(@oldcoder)
I'm expecting the 'speed' to update in the display while the printer is laying down the first layer, and then expecting it to update again after that. Is that not what should happen?
What kind of gcode command should I be looking for? I don't see any M220. Is it just Feedrate changes, like F<number>?
Thank you,
Chris Shaker
Publié : 19/12/2016 1:09 am
Ancientwolf
(@ancientwolf)
Try the colorprint printer profile. I haven't had to use z-hop yet after a ton of prints. I changed the speed a few times on the first layer and it had no problem doing so. Only difference here is I also used the 0.20 normal, since the time difference between that and the 0.35 Fast wouldnt be that much on such a small part.
Publié : 19/12/2016 1:12 am
OldCoder
(@oldcoder)
Thank you. I will play with other printer profiles.
Chris Shaker
Publié : 19/12/2016 1:14 am
Ancientwolf
(@ancientwolf)
Started that print 3 times with extreme first layer changes, and it worked each time. 20%, 40% and 80%.
Publié : 19/12/2016 1:15 am
OldCoder
(@oldcoder)
I just compared the gcode from that first test (first layer speed set to 50%), and the gcode with the first layer speed set to 70%. It looks like the speed differences between the two files are in the Feedrate commands: F1500 vs F2100?
So, the 'speed' in the LCD display will NOT update to match the print speed that I configured for the first layer?
Chris
Publié : 19/12/2016 1:29 am
Ancientwolf
(@ancientwolf)
It's my understanding the speed on the LCD is merely showing absolute printer speed- in other words, youre speed settings at 100% shown on the LCD is just the printer's overall speed unmodified by manual tuning- it doesnt reflect gcode changes.
Publié : 19/12/2016 8:20 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Yes, the printer is printing at 100% for the whole print. The printer setting overrides the speed settings in the GCode file, and is not necessary.
The slicer produces GCode which prints the first layer at 50% of the set speeds; the printer is printing at 100% of 50% (or 50%) for the first layer.
Peter
Publié : 19/12/2016 10:09 am
OldCoder
(@oldcoder)
Thank you AncientWolf and Peter. Thank you for your help and information. I think I've got it now. This is my first time reading Gcode.
Really having fun cranking out parts with the Prusa.
Chris
Publié : 20/12/2016 7:15 am
