Is it possible to create support manually?
avi.s
(@avi-s)
I mostly use Simplify3D and the one option I use there a lot is manually creating and removing individual support columns instead of relying on the software deciding where and how much support is needed. I was unable to find a way to do this in Slic3r. Does Slic3r have this capability?
Here is an example where this is needed:
The red rectangles in this badge are overhangling areas that Slic3r filled with support and it was impossible to remove without destroying the badge. With Simplify3D I created only 4 support column under each overhang and made them so the stuck out from underneath the overhang which made it very easy to pull out using a pair of pliers.
Publié : 13/03/2017 4:42 am
vitor.j
(@vitor-j)
Re: Is it possible to create support manually?
Slic3r does not have the manual supports feature.
Publié : 13/03/2017 11:54 am
Crua9
(@crua9)
This is a needed feature. I'm running into a problem right now where I can use this
Publié : 10/09/2018 7:30 pm
OPK
 OPK
(@opk)
Check out Meshmixer;
These are the only supports I will use. The ones in Slicer are (for me) impossible to remove; especially if you use a larger nozzle.
Publié : 10/09/2018 7:55 pm
[...] These are the only supports I will use. The ones in Slicer are (for me) impossible to remove; especially if you use a larger nozzle.
If you ever have occasion to try Slic3rPE again, try setting Print Settings->Support material->Options for support material and raft->Contact Z distance to 0.25. Once I figure that setting out, I've had no problems removing support without scarring the lower surfaces.
Publié : 10/09/2018 7:58 pm
OPK
 OPK
(@opk)
Thanks bobstro - I tried that; still can't compare to the "tree"-type supports; especially "in" the model. But good to mention it here 🙂
Publié : 10/09/2018 8:10 pm
The frustrating thing is that Slic3r already incorporates the ability to define a "mask" shape to define different print settings. Unfortunately, there's a support option but it can't actually be selected.
Publié : 10/09/2018 8:51 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
https://github.com/prusa3d/Slic3r/releases/tag/version_1.41.1-beta
Publié : 26/09/2018 6:01 pm
Glad to see it! Slic3rPE is a real powerhouse. If layer seam options and automatic adaptive layer heights are expanded (see KISSlicer), I'll have no need for any other slicer!
Publié : 26/09/2018 7:38 pm
