I'm trying to print an object I created in Cinema 4D, it's a cylinder with a solid wall inside. The export to stl goes f
I'm trying to print an object I created in Cinema 4D, it's a cylinder with a solid wall inside. The export to stl goes fine, but when I slice it on Slic3r the inside wall disappears.
Here's the object in Cinema 4D;
And here it is once I slice it on Slic3r
There's probably a simple setting that I'm missing, but can't find it yet. This whole 3D printing thing is still very confusing. Any help is appreciated.
Thanks!
Re: I'm trying to print an object I created in Cinema 4D, it's a cylinder with a solid wall inside. The export to stl go
Do you have your infill set to 0?
Looks like there are no top and bottom layers and no infill.
I think you wolud get two concentric cylinders if you printed it at the moment. Try 15% infill and at least three top and three bottom layers. Preferably more top and bottom layers.
Regards Joan
