How to remove these difficult-to-get-rid-of support?
[Fermé] How to remove these difficult-to-get-rid-of support?
prusanewuser
(@prusanewuser)
Hi, anybody has good suggestions on how to remove the support shown in pic 1 to 3? I cannot get rid of them. Thanks
https://www.flickr.com/photos/183206770@N08/shares/0z0mdr
Publié : 29/03/2020 7:42 pm
RE: How to remove these difficult-to-get-rid-of support?
I use a z distance of 0.25mm, a bit more than the PrusaSlicer default for removable supports. At that height, supports like that can be snapped off with a screwdriver.
Publié : 29/03/2020 10:52 pm
prusanewuser
(@prusanewuser)
I don't know if we are referring to the same thing. My main problems is not getting rid of the support between the object and the build plate but within the object itself. Can changing the z distance help?
Publié : 30/03/2020 12:30 am
I'm referring to the little zig-zag patterns on the plastic, yes. Increase the gap between the support and part slightly.
Publié : 30/03/2020 1:36 am
1 personnes ont aimé
prusanewuser
(@prusanewuser)
Thanks.
Publié : 30/03/2020 2:06 am
prusanewuser
(@prusanewuser)
Any recommended set of tools to help to remove the support? My main problems are those shown in the photos posted in the link and also holes of size M2, M2.5, M3-M5. Sometimes support block the holes.
Publié : 30/03/2020 1:21 pm
Posted by: @peter-c20
I just pop them off with a small knife or wide dental pick.
Publié : 30/03/2020 2:42 pm
I’d second a set of dental picks.
Publié : 30/03/2020 2:53 pm
prusanewuser
(@prusanewuser)
Thanks. Any recommended dental pick products?
How are dental picks compared with drill bits?
Some sites recommended a set of knifes of different shapes (flat, semi-round, triangular) for wood craving. In practice, do you find the semi-round, triangular shaped knifes useful? For the problems shown in the photos, am I correct that I only need flat-shaped knifes of different widths.
Publié : 30/03/2020 3:00 pm
I just bought a cheap set of picks off AliExpress. There's a wider spade design that works best. The thin ones all twist pretty quickly. A small pointy knife works well for most work, but the picks are good for detail areas. I don't use the X-Acto-type blads as I worry about them snapping.
Publié : 30/03/2020 4:26 pm
I got mine from ebay, a set like these https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F233438877710
I also have a set of needle files which is also useful for post processing anyway.
Publié : 30/03/2020 4:40 pm
prusanewuser
(@prusanewuser)
@neophyl
Thanks. I can see that the pointed one is useful. How about the rest? I don't see any use myself as I have not used these tools.
Publié : 30/03/2020 5:14 pm
Posted by: @neophyl
That looks much like the set I bought. The spade style works well.
I snapped a file recently while clearing some stuck supports. I won't use good ones anymore!
Publié : 30/03/2020 5:35 pm
prusanewuser
(@prusanewuser)
@bobstro
How to use that spade style? In what situation? I have not tried but perhaps for my case, a flat rectangular one may be able to remove the support.
Publié : 31/03/2020 2:23 pm
A sturdy small pointy knife blade is the most useful removal tool. However, the pick is good for getting into small crevices on small prints like miniatures. I just use the spade to snag and pull small amounts of support out between things like arms and wheels.
Publié : 31/03/2020 2:31 pm
