How change start point for printing Slic3r PE ?
My surface on heatbed on i3 MK2 is damaged but only little in middle.
So I want to move starting point 40 mm along Y axis from the middle on the heatbed.
Then I can contine use Prusa printer until I receive new print surface.
In Slic3r PE it forces STL obejct into middle all the time.
Where can I change this setting in Slic3r ?
(I can not find answer on your FAQ.)
Postato : 30/01/2018 5:05 pm
Re: How change start point for printing Slic3r PE ?
In Slic3r look at the settings and there you can unbox the setting for placing the object file always in the middle. If unboxed you can place the object where ever you want it.
Let us now if this helped.
Frans
Frans Krau
Europe, Holland, Apeldoorn
Postato : 31/01/2018 8:59 am
