[Fermé] Hatchbox PLA Settings
Nathan
(@nathan-5)
Hello,
I recently ran out of the PLA that came with my MK2 which worked amazingly well. I bought some hatchbox pla of amazon and am having a few problems with it. Mostly it looks like it might be over extruding. I am using the same profile as for the prusa pla and an wondering if anyone on here has a tweaked slic3r profile for the hatchbox brand and would be willing to share what worked for them.
Thanks,
Nathan
Publié : 20/09/2016 3:19 am
David T.
(@david-t)
Re: Hatchbox PLA Settings
Did you check filament diameter? If it is bigger than 1.75mm, you will get overextrusion very easily.
Publié : 20/09/2016 9:14 am
PJR
 PJR
(@pjr)
Antient Member Moderator
If the plastic is slightly harder, that can also cause over-extrusion.
Ideally each filament make and colour should be separately calibrated, although practically that is not the norm.
Peter
Publié : 20/09/2016 9:38 am
Nathan
(@nathan-5)
The diameter averages to 1.75, I tried to reduce the print temps from 210 down to 205 which helped a little, I may try to go even lower. I created a new profile so I will continue to tweak until it prints perfectly was just hoping someone would have some starting numbers since hatchbox seems to be fairly popular.
Publié : 20/09/2016 5:44 pm
richard.l
(@richard-l)
Membre Moderator
I use 195 for most of my Hatchbox filament. Bed temp is the same as for Prusa filament.
Publié : 20/09/2016 8:08 pm
Kyle
 Kyle
(@kyle-2)
Membre
I typically use 200 and 55.
Love Hatchbox PLA 🙂
Publié : 20/09/2016 9:30 pm
Nathan
(@nathan-5)
Thanks for the replies, did you have to change anything other than the temperature like the extrusion multiplier or any speeds?
Publié : 20/09/2016 10:36 pm
erron.w
(@erron-w)
I used to like Hatchbox PLA, but in my recent experience, their quality seems to be lacking the last few months + they have had major issues actually keeping it in stock on Amazon (were i get it) and i go through ALOT of filament (15+ rolls a month)
When i did use them though yea, I got the best results setting the temp a little lower than standard, (205ish)
Publié : 24/09/2016 7:51 am
mikedan
(@mikedan)
RE: Hatchbox PLA Settings
I've been printing Hatchbox PLA a bit lately. Here are the settings that work for me on my MK3s:
  • Hotend: 200
  • Bed: 55
  • Extrusion multiplier: 1.03
  • Fan: off for first 2 layers
  • Print speed: 50% for first 2 layers
  • Brim: 5mm (not sure I need this, just being cautious)
Enjoy!
Publié : 07/04/2020 5:22 pm
