Getting a 45 degree taper on the base of all my PETG prints
Thou Off Dead Center
(@thou-off-dead-center)
I'm trying to dial in my spool of Prusa PETG but a keep getting up the bottom 2mm/1.5mm of my prints for 0.2/0.15 layer heights respectively. I'm using a Prusa MK2 and slicing with the stock Prusa PET settings in Prusa3D Slic3r. The only times this doesn't happen is sometimes with parts with this bases(about 5mm) but sometime they get it too. I was also getting under extrusion on the first layer but after I tightened up my up the springs on my extruder that hasn't been a problem
Opublikowany : 14/07/2017 2:52 am
