Filament issue
PJR
 PJR
(@pjr)
Antient Member Moderator
Filament issue
Hi Guys
In the middle of printing a model; 1 x 13 hour print complete and 3 to go. Short on filament, so I can't afford to waste any... Should just about be able to complete the model.
Then, 3 hours into the second part, I hear the filament pulley skipping. Couldn't work out why, so I stopped the print, reduced the temp to 95 degrees and pulled the filament, expecting to see some blockage in the PTFE tubing.
Then I noticed a bulge in the filament:
I have to say that this is the first time in almost 2 years I have seen anything like this, but I am a little miffed as I probably won't have enough filament to complete the model. Re-slicing now, in an attempt to reduce the amount of filament the rest of the print needs...
Peter
Publié : 30/08/2016 12:49 pm
David T.
(@david-t)
Re: Filament issue
Bad luck, really.
Any chance to slice only unfinished part and then glue it together?
Publié : 30/08/2016 12:57 pm
PJR
 PJR
(@pjr)
Re: Filament issue
David
I agree it is bad luck, but unfortunately, it cannot be glued - it has to hold water.
Peter
Publié : 30/08/2016 1:21 pm
