Estimating print time with slic3r
Hi, I can't find where the estimating print time is in slic3r. Thanks
Re: Estimating print time with slic3r
Oh, now that you mention it, i can't find it either.
You can't find it because it doesn't exist in slic3r. You can upload the gcode to http://gcode.ws/# and it will give you all the information.
OK, thanks. I'll try.
This is an upcoming feature in the next release as I understand it. It is being worked on currently. Soon...
I too would like to see this feature added
#necrobump but I guess "not so soon" after all. Too bad. I really like Slic3r but I often toy around with settings to see how they impact print time to decide if it's worth it to me. In that area Cura does a lot better.
XL (5T) / CORE One / MK3S+-MMU3 / MK3S / Mini / SL1S
You do realize he posted this in 01-2018 and not in 01-2017 when the thread was initially started. Five days from his post to yours. Not long at all.
Now that you mention it... I was looking at the "join" dates. Thanks for pointing that out 😉
Well then, my +1 for this feature I guess.
+1 for me too - coming from a non-Prusa printer onto my first (MK3), I was previously using Cura, but love the simplicity of Prusa Slic3r and all the given pre-sets! I always add the estimated print duration to my saved Gcode files, and having that value available after slicing, and before exporting the Gcode, simplifies this massively. I guess for now i'll have to parse it online, and update the filename afterwards 🙁 Octoprint's print time estimation sucks in comparison to the Cura one too...
Someone on FB compiled dev version of new version of Slic3r, where this feature is implemented. Jo commented that there will be FW simulator in Slic3r, so the estimated time will be very precise (max. 5% error). 😉
The latest Slic3r beta release has an estimated printing time: https://github.com/prusa3d/Slic3r/releases
Design, Print, Repeat
+1 for adding some kind of indication on time on a part!
Hey ! i read on the email send to prusa owner that the time estimation will be available on the Slic3r 1.3.9. i update my slicer but i dont find the time estimation option ...
MK2S and MK3 owner
Time is shown after g-code is saved.
-Kevin
Ok my bad 🙁 Thanks ! it works really well !
MK2S and MK3 owner
Hi, why not show the time estimation after slicing? You always adjust a bit here and there to see how the printing time changes before storing the gcode to the SD-Card.
+1
MK2S and MK3 owner
+1
+1
There is a github issue on this topic:
https://github.com/prusa3d/Slic3r/issues/800
PRUSA MK2
- Noctua fan 40mm
- MK2/MK3 hybrid extruder
