Diagonal scarring
wless1
(@wless1)
Diagonal scarring
Hello everyone,
I've just got an MK2S and it's been printing great. I am noticing minor diagonal scarring, and was wondering if anyone could take a look and let me know what I might be doing wrong.
Here's a picture - https://imgur.com/a/IuTqj - the scarring is the three diagonal lines that you can just make out.
Thanks for any help!
Opublikowany : 30/09/2017 8:02 am
AJS
 AJS
(@ajs)
Re: Diagonal scarring
Very hard to tell anything from your photo.
Try Setting: Layers and Perimeters -> Advanced -> Seam position: to random and see if that helps.
Opublikowany : 30/09/2017 5:35 pm
are you using cubic infill?
this sometimes causes surface blemishes in diagonal lines
more perimeters, or print outside perimeter first often helps, but outside perimeter first, sometimes messes up curved exterior surfaces.
Opublikowany : 30/09/2017 6:26 pm
