[Fermé] Corners Lifting
ken-3
(@ken-3)
Corners Lifting
Recently I have started having a problem with corners lifting. I had been printing successfully, then suddenly everything falls apart in the first few layers. I'm using ABA. I am also try to print a much wider object than in the past.
Publié : 16/03/2020 8:16 pm
rmm200
(@rmm200)
RE: Corners Lifting
ABS shrinks - a lot.
If you have a big object, I think an enclosure is required. Otherwise the corners will lift...
Mouse ears might help - but ABS really wants to shrink.
Publié : 17/03/2020 3:54 am
1 personnes ont aimé
Peter M
(@peter-m)
RE: Corners Lifting
A " photo tent" can help(is cheap), or get silver isolation foam(see YouTube for example), then you can build yourself. Or a cardboard box.
Add a big brim connected to the part, and/or glue stick.
Print 10 or more degrees hotter can also help.
Put filament in oven to get water out of the filament.
Last week i printed ABS, and it crack on a lot places, hotter helpt.
Publié : 01/04/2020 8:56 pm
ken-3
(@ken-3)
RE: Corners Lifting
Thank you! I moved the printer to the warmest room in the house and that solved the problem. I also fine tuned the bed leveling.
Publié : 01/04/2020 9:21 pm
