Color Print app no longer working?
Wirlybird
(@wirlybird)
I just tried to set up a Color Print - print. The app is not working. I enter a value then move to enter the next one and the one I entered is reset to ".2".
No matter what I do any values I enter are erased. I am using the Slic3r settings for Color Print. I has worked in the past.
Thanks for any thoughts.
Respondido : 17/02/2017 12:07 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Color Print app no longer working?
I once tried to use the app to insert the M600 code, but found it much easier and more accurate to enter it manually, which also works when using Z-Lift.
There's plenty of threads here explaining how.
Peter
Respondido : 17/02/2017 9:58 am
JeffJordan
(@jeffjordan)
Miembro Moderator
😀 i totally agree to PJR.
🙄 the app simply is overstrained when you use z-hop (z movement when retracting). the better way is to add the M600 command manually with an editor into your gcode file.
➡ therefore i recommend to enable adding comments to the gcode inside the slicer of your choice. it makes things much easier when you try to find the start of a layer and differentiate it from retraction movements.
Respondido : 17/02/2017 11:53 am
