Cleaning ABS juice spray sprinkler ?
christophe.p
(@christophe-p)
Utenti Moderator
I have an issue with the ABS spray (the one provided with my printer) which seems a bit clogged, it does not spray mist anymore.
What is the best way to clean it without damaging it ? Did you have the same issue ?
Thanks for any hint.
Christophe
I'm like Jon Snow, I know nothing.
Postato : 23/03/2016 10:04 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Cleaning ABS juice spray sprinkler ?
Christophe
I would guess that the best cleaning solution would be pure acetone (not the finger nail stuff...)
Peter
Postato : 23/03/2016 10:56 pm
fl0PPsy
(@fl0ppsy)
Put the top of the spray bottle into some acetone over night to soak. In the morning it will be fine.
Postato : 24/03/2016 8:57 am
christophe.p
(@christophe-p)
Utenti Moderator
Thanks for the tips guys, the top of the spray is right now soaking in a small botlle full of acetone, I will check the result this evening.
By the way I'd like to print a small funnel to ease filling up small recipient from my 5L acetone container. ABS is of course out, but between PET and PLA, which is the best filament for that ?
Postato : 25/03/2016 12:12 pm
PJR
 PJR
(@pjr)
Christophe
For the funnel, I would suggest PLA; I think you would be able to over-extrude slightly and increase temp a tad to ensure no gaps. PLA would probably be easier to ensure no delamination occurs.
Peter
Postato : 25/03/2016 1:17 pm
christophe.p
(@christophe-p)
Utenti Moderator
My ABS Juice spray is fixed. Thanks for the advice.
Postato : 29/03/2016 3:37 pm
