Can anyone share print settings when printing with at .3 layer height w/ .4m nozzle?
david.b14
(@david-b14)
Specifically I am looking for setting using PLA:
- max print speed settings
- extruder flow multiplier value
Thanks for any info you can provide.
The current .3 corse profile does the job, but the layers bonding could be better (I know I really should buy a larger nozzle when using this profile).
Veröffentlicht : 08/05/2017 8:53 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Can anyone share print settings when printing with at .3 layer height w/ .4m nozzle?
David
Max speed settings can easily be calculated from a base of E3D's melt figure of about 10mm^3/s. There is no reason why you would need to change any multiplier.
Personally I don't go above 0.25mm layer height. There's not much additional benefit from going any higher.
Peter
Veröffentlicht : 12/05/2017 12:23 pm
david.b14
(@david-b14)
Printing at .3 vs. .25 should reduce the time to print a part, no?
For example, printing an object that is 20 cm tall at .25 will take 80 passes.
Using a .30 will only take 66 passes which I think in theory would reduce the time to print?
Veröffentlicht : 13/05/2017 2:47 am
